1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 45 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 45 | I have a vintage air ac system that was installed by my mechanic. He added a toggle switch rather than wiring it through the ignition key. When I stopped the truck I hit the toggle and it kept running. With further inspection I found that the fuse installed just behind the switch was melted to a mush of plastic.It is easy enough to replace the fuse, but what would have caused it to over heat and not blow? | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | A loose, dirty, or poorly-crimped connection can develop a significant amount of heat without exceeding the current capacity of a fuse. Installing a fuse way above the current carrying capacity of the wire involved can also lead to overheating, such as using a 30 amp fuse on an 18 gauge wire, for instance. Fuses are supposed to protect wires, not the end item in the circuit. It sounds like you need to find a better electrician, before this guy burns your truck down! Jerry
