2 members (BC59, Uncles51), 103 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#1043780 07/20/2014 8:02 PM
I have a vintage air ac system that was installed by my mechanic. He added a toggle switch rather than wiring it through the ignition key. When I stopped the truck I hit the toggle and it kept running. With further inspection I found that the fuse installed just behind the switch was melted to a mush of plastic.It is easy enough to replace the fuse, but what would have caused it to over heat and not blow?
Who owns this car with the peace sign, mag wheels, and 4 on the floor?
Dude- 1948 Chevrolet Thriftmaser 3600
https://i.imgur.com/NN2ehrsl.jpg
jjrockbush #1043782 07/20/2014 8:18 PM
H Online: Content
A loose, dirty, or poorly-crimped connection can develop a significant amount of heat without exceeding the current capacity of a fuse. Installing a fuse way above the current carrying capacity of the wire involved can also lead to overheating, such as using a 30 amp fuse on an 18 gauge wire, for instance. Fuses are supposed to protect wires, not the end item in the circuit. It sounds like you need to find a better electrician, before this guy burns your truck down!
