| | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | Is there a way to adapt an electronic speedometer to my old gauge in my 1950 Chevy pickup? Is there a reasonable way to do this? Thanks,RegMudd | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | do you mean you want to put an electronic speedo in the hole the original speedo was in? would probably start by some searching to see if you can find one that's the same diameter and then see how it mounts and if it might be adaptable - if you mean put the electronic guts behind the original face, that'd be a DIY project that won't be simple, considering the calibration of the new one likely wouldn't match the original numbering
Bill | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i found an electronic conversion for my 46 1/2 ton with an 89 t-5 transmission....checkout..www.abbott-tach.com they have a conversion kit from electronic plug on the trans to cable that screws into the back of the speedometer...called "cable x"
