5 members (Jon G, baldeagle, Nick in Manitou, TexasJim50, Woogeroo), 66 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#1043601 07/19/2014 10:45 PM
Is there a way to adapt an electronic speedometer to my old gauge in my 1950 Chevy pickup? Is there a reasonable way to do this? Thanks,RegMudd
do you mean you want to put an electronic speedo in the hole the original speedo was in? would probably start by some searching to see if you can find one that's the same diameter and then see how it mounts and if it might be adaptable - if you mean put the electronic guts behind the original face, that'd be a DIY project that won't be simple, considering the calibration of the new one likely wouldn't match the original numbering
i found an electronic conversion for my 46 1/2 ton with an 89 t-5 transmission....checkout..www.abbott-tach.com they have a conversion kit from electronic plug on the trans to cable that screws into the back of the speedometer...called "cable x"
