2 members (Ponchogl, 1955 1 Series), 376 guests, and 4 robots.
Topics128,163
Posts1,057,044
Members48,463
I
Junior Member
Junior Member
I Offline
Hi all,
I'm tinkering with a 63 fleet and just got a new bed for it. I need to fill the holes left from the trum molding which I took off the bed. I don't want to put trim on the cab and fenders to match the bed. I also like the clean look. Looking for suggestions for the best way to fill the holes.
Thanks much
Thanks, Ivor
63 chevy short/fleet 292/4speed
under construction
Anonymous
Unregistered
Anonymous
Unregistered
Mig Welding although I have heard of JB weld being "pressed" into service for this.
I second the Mig welding. Take an 8" length of 3/4" copper pipe and flatten about 4" of one end with a hammer. Clamp the flat end in a vise and bend the pipe in the middle so it's at about a 45 degree angle. When it's done, it should look like a spatula with the round end the handle and the flat end the blade. Either hold or have someone hold the blade on the back side of the hole and with the welder, start to fill in the hole. The weld will not stick to the copper and it allows you to fill a pretty good size hole. Then grind and prep as usual.
1959 Chevy Apache Stepside 4x4
2009 Chevy Silverado 2500HD Duramax/Allison LB Crew Cab
I
I Offline
RSGS I have never seen that explanation before.
That will be helpful.
Holes look out!!!!!
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
For backing in difficult areas I use a piece of 16 gauge copper flashing held in place with a magnet. A round grouding magnet for arc welding works great and you can attach your mig ground cable right to the magnet. Available at Harbor Freight for very little money.
Two hot tips! I'd heard of using copper to back up holes but wondered how to accomplish it.
I tried the tip today with the 3/4 inch copper pipe and it is terrific! I was filling holes like never before...
Thanks alot!
Andy
A man is like an old truck... He will rust out before he wears out...
