6 members (Rusted Nut, Lightholder's Dad, Bill Hanlon, Hotrod Lincoln, Buckeye998, 1 invisible), 87 guests, and 3 robots.
Topics128,091
Posts1,056,393
Members48,442
#1038673 06/29/2014 7:52 PM
Working on a 49 3600. Decided to leave the front hubs as is and put in a lower number rear end like maybe a 3.73. I read somewhere that a rear axle from a 1967 - 1973 3/4 ton would fit. Anything newer than that work?
Hi, I have a 1948 3600 and I have been trying to do the same. Nothing fits 100%.
I have been looking for a 67-72 eaton 4:10. The front section, 3rd member will bolt right in.
If you find out anything else, please let me know.
Got a 66 1/2 ton rear I'm going to try. If I ever get it put in there, I'll let ya know.
I used the rear out of a 69' F250. It's almost exactly the same width drum to drum. It rquires having the drive shaft shortened and the yoke changed to mate up to the pinion and spring perches welded on. The one I found has 3.73 gearing.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
If any of you guys have the 3600 Axel laying around - I would like to buy the E-brake parts from inside the drum/brake
Thank you!
Kaad
Post a Want Ad in the Swap Meet (or use email/PM for personal transaction)?
