9 members (Sjm, moparguy, SmalltownTRKGuy, Jman, baldeagle, carbking, walter74, Wooley, 1 invisible), 334 guests, and 5 robots.
Topics128,165
Posts1,057,089
Members48,463
I have a 1940 suburban with a 216 Eng . can anyone tell me if this motor takes a short water pump and the dimensions for it,i think i have the wrong pump (tall installed cause the radiator does not clear.
Roadmaster Panel Club Alumni
V
V Offline
Looks like there are two options for your 40 216, a TALL pump or a SHORT pump.
Do you still have the old pump for comparison?
Looks like the process of elimination has determined you need the short pump. Also looks like they're pretty proud of them.
Good luck
Dave
thanks for your reply,like a dummy/novice switched my original for this one at a swap meet about 20 yrs ago this burb has sat that long but on the road to recovery ,the short one it is thanks
