1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | I'm about to put my painted cab back onto the chassis , should I refit the steering column after or before I fir the cab .please.,..?
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I added mine after the cab was set, here are my reasons. With no frame support it is held only by the column clamp, not a great idea so you would have to wire or tie it. It adds another 75 pounds to the lift for no good reason I can see? After cab is set it will still need to be bolted to the frame, column clamp assembled with correct washers, rubber isolator etc. I Just don't see the advantages anywhere. https://www.flickr.com/photos/advance-design_parts_co/8129051329/in/set-72157631867396207 | | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | | | |
