8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#1043023 07/16/2014 9:18 PM
How much gap or play can a tie rod end have and still be okay ?
Same goes for front wheel bearings.
A certain amount of play is okay but how much ?
Any referance somewhere ?
I tightened one of the wheel bearings, it was quite loose. Now both sides have some play still.
Still waiting for my new tie rod ends to arrive in my mailbox.
Br /Ulf
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
Riding in the Passing Lane
There should be no play at all in the tie rod ends or the wheel brgs. In isolated cases the spindle may be worn where the brgs ride on. In that case its better to have a small amount of play rather the over tightening the brgs. to compensate for it. A little play in the kingpins is tolerable but should be repaired.
1972 Chevy c10 Cheyenne Super
Thanks. I will replace all bearings and both tie rod ends.
The problem is that the safety test company in Sweden don't care about a comment like yours, I have a lose bearing due to wear in the spindle.
They will still say the play is not supposed to be there and then ask me to replace the spindle too smile
I will tighten according too the shop manual with the wheel off.
[email protected]
Also:
