8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 9 New Guy | | New Guy Joined: Feb 2007 Posts: 9 | 68 k-20 when park and tail lamps are turned on 20 amp in the fuse box gets hot i have replaced the light switch wires under dash seem to be ok thanks | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Heat indicates resistance. Try removing the fuse and giving the holder a good scrubbing with a small wire brush like a rifle cleaning brush. It's not uncommon for a fuse holder to get a layer of oxidation on the contact surfaces. Jerry
