7 members (Steve L., WICruiser, Bill Hanlon, Bucker, Peggy M, Hotrod Lincoln, klhansen),
68
Mod | | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Hello- I'm in the process of installing the three chrome strips on each side of the hood of my 46' Chevrolet pickup. Could someone help me with there placement? Should the ends all line up or were they offset at an angle because of the slight angle of the strip ends? If you have a 46' also could you tell me where the middle one starts in relationship to the distance from the rivet that holds the locking mechanism on the back. Thank you. Jim- | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Yes, I do have the holes in the side pieces, but I'm looking for an exact position that they may have been installed at the factory. I was thinking that someone may have an unrestored vehicle that could help me out. Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | did you look at the linked gallery pictures? the trim strips are aligned with an even amount past each end of the louvers, restored or unrestored
Bill | | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Red58-
I did look at the photos and thanks for sending them. I think I am in the ballpark as far as positioning, but I can't see from the photos if the end of the strip is angled up or down.
Jim- | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I don't see [or recall] any angle on the trims, maybe a bit of angle on the louvers - just like from the ad Drew posted, maybe you don't have the correct trims? Bill | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | They slope with the hood louvers. I put mine back in the same location they were removed. I could tell by the clip stains on the back sides. Iam on the road and can,t give you a measurment. Who knows but I bet they were done by eye back then. These were work trucks.
| | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Thanks for all your help guys, I'm going for it. | | |
