2 members (TUTS 59, KingG),
106
Mod | | | Forums66 Topics128,026 Posts1,055,400 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | why I thought I was hearing an exhaust leak. New gasket set will be here in the morning. I think I know what I'll be doing tomorrow.
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Tiny, do you carefully tighten the manifold bolts slightly prior to loosening them? I have never broken one after doing that. An old timer showed me that trick (very likely your elder.  ) I don't know how it works, but it does. I don't know how electricity works either, but the lights still come on and I still get a bill. Carl
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't normally but I'll try it in the future if the need arises. I did find out why the gasket burned through. The bolts were little more than hand tight. I don't know what, if any, the torque specs are but I know they'd be tighter than that. The folks who stuck the engine back in after the rebuild seemed to have forgotten to tighten them down.
