2 members (Roxxstar, 1955 1 Series), 298 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
What is the thickness of the rubber bushing? The old ones are squashed near flat and badly cracked. I will be reassembling all the sheet metal to check for fit, before taking apart again for paint. I am considering making these bushings myself or buying locally, if possible.
Hi 46Sparky are you talking about the ones that go between the cab & frame?
They should be wood not rubber. The factory used wood blocks between the cab & frame.
I beleive Jim carters sells them.
http://www.oldchevytrucks.com/cart/index.asp?cat2=9665&path=1934+-+1946+Truck+Parts%2FCab+Related+Parts%2FCab+Mount+Kits
No. Those I can make, as I have the old for a pattern.
There was a spring, bolt, thick steel washer and a rubber bushing/ washer at the cab rear. I have photos of these before removal and the parts afterward I'll post a link for later.
Here is a photo of the hardware mounting the cab to frame. This is at the rear of the cab.
Cab hardware with rubber washer/bushing
Hey 46Sparky, I have a new set from Jim Carter and they are 3/4" deep.
Dennis
40 Chevy 1/2 ton
Thank you, Dennis!
