7 members (68ironhead, Ol'55, 3B, baldeagle, Otto Skorzeny, gswbbc, 1 invisible),
104
Mod | | | Forums66 Topics128,039 Posts1,055,473 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | I am trying to find out how the firewall control for the heater works internally. Has control under dash that works by a rod. Does any one have an exploded view of this copper piece that come thru the firewall and the hoses connect to it. Notice that as soon as I open a window, it appears that the pressure level allows air to pass thru the heater box and into the truck cab. All hoses are really hot, so I do not think the control is stopping flow. Have thought about another valve in the hose line but the engine bay is really dress up for show truck look. Thanks for any help. Tom Duffy Cadillac, Mi. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that would be the Ranco valve, usually it won't totally stop water flow - if it's not dripping inside the cab it's working as well as it can  if you want to totally shut off water to the core in summer the usual thing to use is a simple shutoff where one hose attaches to the engine, could be chrome if it needs to be 'showy' Bill | | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | Thanks - Bill. The Ranco valve is more like flow adjusted than an on/off valve. I think I can put a valve on the lower hose in the middle of the inner fender and then run a vent style pull cable to the bottom of the dash. This will make it controllable from inside. I did this on my 56 pickup with standard heater and deluxe controls. Hooked it to Temp arm (travel not enough). So when the control is off the valve if off but when all the way on the valve is 60% on (enough to heat the cab.). | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, I did just that on a friends 56 panel with an aftermarket heater, works fine and not obtrusive
Bill | | |
