| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | What is the thickness of the rubber bushing? The old ones are squashed near flat and badly cracked. I will be reassembling all the sheet metal to check for fit, before taking apart again for paint. I am considering making these bushings myself or buying locally, if possible.
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Hi 46Sparky are you talking about the ones that go between the cab & frame?
They should be wood not rubber. The factory used wood blocks between the cab & frame.
I beleive Jim carters sells them. http://www.oldchevytrucks.com/cart/index.asp?cat2=9665&path=1934+-+1946+Truck+Parts%2FCab+Related+Parts%2FCab+Mount+Kits
| | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | No. Those I can make, as I have the old for a pattern.
There was a spring, bolt, thick steel washer and a rubber bushing/ washer at the cab rear. I have photos of these before removal and the parts afterward I'll post a link for later. | | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | Here is a photo of the hardware mounting the cab to frame. This is at the rear of the cab. Cab hardware with rubber washer/bushing | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Hey 46Sparky, I have a new set from Jim Carter and they are 3/4" deep.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | | | |
