5 members (Phak1, BC59, MickeyP, Oldcaliforniakid, Gdads51), 85 guests, and 2 robots.
Topics128,049
Posts1,055,667
#1042063 07/13/2014 1:19 AM
My 53, 3600 is stock, new wiring and lights. But the lights are dim, and hard to see.How can I get them brighter? Can I get them so you can see them in the day and night,like halogen? Thanks, Paul
Try something like these:
http://www.mikeschevy.com/servlet/the-3765/6-VOLT-HALOGEN-GLASS/Detail
There might be better prices if you look hard enough
Steve H
For tail and stop lights see what watts are in there now. You might get lucky and find some that are more watts, they will be brighter.
Steve H
Are you 6v?
Are you opposed to led bulbs?
...search for your socket style...
Ex Hall Monitor
Ex Hall Monitor
#1: Put in a plastic lens. They let a lot more light through than glass.
#2: Check your bulbs. If you have this type of tail light use a #81 for the tail light and a #1129 for the brake light. That will give you a brighter tail light than a 12v #1157 and almost as bright a brake light.
#3: Make sure your socket & connections are clean & not corroded. Good clean connections are a must for a 6v system.
#4: Paint the inside of your housing gloss white.
My 6v tail light on the left with the above noted mods, my modern truck 12v on the right.
