7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl),
112
Mod | | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | My 53, 3600 is stock, new wiring and lights. But the lights are dim, and hard to see.How can I get them brighter? Can I get them so you can see them in the day and night,like halogen? Thanks, Paul | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | For tail and stop lights see what watts are in there now. You might get lucky and find some that are more watts, they will be brighter.
Steve H
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | #1: Put in a plastic lens. They let a lot more light through than glass. #2: Check your bulbs. If you have this type of tail light use a #81 for the tail light and a #1129 for the brake light. That will give you a brighter tail light than a 12v #1157 and almost as bright a brake light. #3: Make sure your socket & connections are clean & not corroded. Good clean connections are a must for a 6v system. #4: Paint the inside of your housing gloss white. My 6v tail light on the left with the above noted mods, my modern truck 12v on the right.
