5 members (lumbersawyer, Nick in Manitou, Wally / Montana, Sjm, Peggy M), 135 guests, and 4 robots.
Topics128,264
Posts1,058,357
Members48,485
#1042044 07/13/2014 12:18 AM
Something let loose inside my 235 the other day. I finally got the truck towed home and have started to open up the engine to see what's wrong. I took all the bolts out of the oil pan, but the last guy who was in there used plenty of gasket sealer and the pan won't move. I don't want to damage the pan or block. So the question: how do I get that thing off? Yes, the engine is still in the truck-I'm hoping it can be repaired in place.
Question 2: if this engine is a bigger job than I can do right now, what would be a direct, drop-in replacement? It seems that I can buy a used engine for just a few hundred dollars and that might be a way to get the truck back on the road quickly. Eventually, I want to rebuild the original and put it back in, but I need the truck running as soon as I can get it.
The truck is a '46 PW 2-ton grain truck that I use on my farm.
Ed Hotaling #1042062 07/13/2014 1:19 AM
For the truly stuck oil pan I have found that a putty knife, about 1 1/2 inch wide can be driven into the gasket to start cutting it loose. It won't bend the pan and won't scar the block. Start where you can and use a hammer to drive it into the gasket keep going until you can move it and it will come off. Then you get to clean all the goo off but it will come apart. Have fun.
Steve H
Ed Hotaling #1042064 07/13/2014 1:27 AM
Any 1941-53 216 or 1941-49 235 will drop right in.
A 1950-62 235/261 will need a different manifold. 1955-62 will need water pump mods and some other small adaptions depending on the year of the engine.
My Blog
Ed Hotaling #1042073 07/13/2014 1:55 AM
Thanks, Steve and Dave. I expect to be back with a lot more questions over the next few weeks.
Ed Hotaling #1042075 07/13/2014 2:07 AM
The putty knife is your friend here!
1951 1 Ton Completed
