5 members (Oswald, DadsFirstPickup, Hotrod Lincoln, J Lucas, 1955 1 Series), 66 guests, and 1 robot.
Topics128,047
Posts1,055,622
Hey All
while I have the pan off, im taking off the main caps and looking at the bearings.
the front 3 main bearing caps on my 261 dont have washers. Shouldnt there be washers? - I havent looked at the rear yet.
Its a 1956 261
thanks in advance
jay
GM parts book only shows lock washers used up to 1955 0.060 in parts book.
If you remove the washers make sure the bolts do not bottom out without them.
My Blog
i dont have washers on the mains currently.
I was trying to make sure this is the way its supposed to be. - wink.
so if washers were only used up to 55, then I guess my engine doesnt use them.
thanks for the info!
