| | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | Hey All
while I have the pan off, im taking off the main caps and looking at the bearings.
the front 3 main bearing caps on my 261 dont have washers. Shouldnt there be washers? - I havent looked at the rear yet.
Its a 1956 261
thanks in advance
jay | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | GM parts book only shows lock washers used up to 1955 0.060 in parts book. If you remove the washers make sure the bolts do not bottom out without them.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | i dont have washers on the mains currently. I was trying to make sure this is the way its supposed to be. - wink. so if washers were only used up to 55, then I guess my engine doesnt use them. thanks for the info! | | |
