1 members (Otto Skorzeny), 105 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
There are two components under the seat that I cannot easily locate in the Service Manual. One seems to be an oil filter or booster pump. The other seems to be related to the vacuum system as it comes from the manifold.
Anyone with knowledge of what these are?
Components under seat
Vacuum booster ? under cab
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
Bob,
Take these guesses with grain of salt.
I have a 1954 GMC COE and there are a variety of differences in comparison to 1954 Chevrolet COEs.
I'd bet the canister in the foreground of the first photo is an oil filter. See if you can trace/track the lines to the block.
The second photo looks like a hydrovac unit for the brake system. If it is, it should have a large vacuum line and a brake line attached to it.
brake hydrovac unit under the floor, under the seat bits are probably parts of it
The part with the line attached sorta looks like the air intake filter for the hydrovac booster. My 59 GMC has one similar to that mounted on the right firewall. If it is, it will have a dry paper filter inside.
The other object looks like a breather cap of some sort.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Thanks all
One is definitely a hydrovac brake unit. I'll pull that out and start cleaning it. OldGMCGold properly identified the breather cap that comes up under the seat.
The other sure seems to be an oil filter of some sort. It has tubes that go in and out of the bottom of the engine block.
Bob
Bethesda, MD
Fantastic - thanks Brad.
I sure hope I don't need any replacement parts. I bet those are going to be hard to find.
Bob
Bethesda, MD
Brad
Any way you can send me the Hydrovac filmstrip as a PDF? I like to save that kind of stuff in a digital file and can't figure out how to do that through Flickr.
[email protected]
No worries if you can't. Thanks again
Bob
Bethesda, MD
