1 members (Forty9), 66 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1041584 07/11/2014 2:23 AM
I own a 49 1/2 ton with a 54 engine, but still has the original rear end. does anyone have a suggestion as to what year new rear end to look for and where???
billm #1041619 07/11/2014 4:11 AM
We need an idea of what your plans are for the truck before we can recommend a rear end or a tranny change.
billm #1041702 07/11/2014 3:47 PM
There is always the ring and pinion swap (3:55 to 1) using the original housing....
billm #1041769 07/11/2014 9:40 PM
Sorry.. It will be just a restored work truck, but needs to drive at highway speeds...65-70 mph
billm #1041824 07/12/2014 1:38 AM
You can buy a ring and pinion set for 3:55 ratio that you swap in your existing differential and torque tube in place of your 4:10 gears.
billm #1041825 07/12/2014 1:40 AM
The only other way to get to 65 mph would be to swap in something like a modern 5 speed T-5 transmission and open type differential.
