I upgraded my driveline and ended up needing 5 bolt rims. Are there any stock 16" or 15"rims that I will be able to use the original hubcaps with? Carter has 5 bolt rims but you have to buy their hubcaps as well.
Also any suggestions on tires would be appreciated. i've got a 235 with a T-5 transmission and S-10 4:11 rear.
