| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Here's a pic of my 235: http://i.imgur.com/WSIBfOz.jpgWhen I bought it it still had a rebuild tag on it from '00. Would that account for the different colors? It's mounted and waiting for a balancer and water pump. Should I paint it or leave it rough (the truck is going to be likewise rough)? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | most rebuilders paint any Chevy engine orange - I don't think any truck 235 was orange, I much prefer them gray, and a fresh paint job is much nicer to deal with for tune ups and repairs, as well as showing a "workman-like" attitude  Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That engine, as Bill posted has "rebuild-orange" valve cover (and, maybe head), and it looks like the block in 261 green? Here are locations of ID codes. Find the codes and post them here - people will then help you ID the engine. 5 codes: block casting code block-date casting code head casting code head-date casting code engine serial number | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Looks like the front clip is off
Nows the time to do it.
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | jrdamien- Your picture tells the story that we are in a similar spot. For me, the only part of my truck (at this time) that will be pristine is the engine & every square inch under the hood. Here is an example of the before & after difference on the exhaust & intake. Not finished there, but it's a gray color example for you to look at like Bill mentioned. I'm waiting for a slot to free up with the machine shop for my 235 to get examined-- in the meantime I'm doing all the scrubbing, blasting, cleaning, and priming/painting I can on the original mechanical parts. It helps me stay motivated & appreciate the (_____?) hard work/pride/detail that went into the parts. And, my wife can appreciate new shiny paint. She didn't much notice the new starter brushes when I installed them. Just my opinion, but it is a whole lot easier to access that 235 to paint it where you have it right now. Brad Wrench Fetcher, PhD | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | If you find out that it is a 261, make sure that you either install the remote oil filter or run a bypass hose between the two oil filter line ports in the block. A 261 will not run long otherwise.
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Block 3769716 (1958-1962) Date Code: J 17 0 (Oct 17, 1960 (1961 model year).
Serial Number: FI0I8BE (Originally assembled at Flint, Mich factory, assembled Oct 18th with a powerglide attached)
Head 3836848
This engine came from a truck during a V8 swap but wasn't this for a car because of the power glide?
It has a car balancer. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1960, the E suffix in the engine code indicates car 235 with Powerglide.
That engine might have move among one or more recipient/donor vehicles during its life.
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | In 1960, the E suffix in the engine code indicates car 235 with Powerglide.
That engine might have move among one or more recipient/donor vehicles during its life. Cool. Makes sense. | | |
