7 members (TUTS 59, classicfins, KEVINSKI, MaxStewart, HandyAndy, Otto Skorzeny, 1 invisible),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,584 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 20 New Guy | | New Guy Joined: Jun 2014 Posts: 20 | Hey Folks, New guy here.. I am trying to replace the bushings in my clutch and brake pedals. I got the clutch one off but can't see what has to be removed to get the brake pedal off the assembly that bolts to the bell housing. Is it pressed, allen socket, or ?? Thanks in advance. Troy | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Troy,
Welcome, and good to see another early Chevy in NC.
Both pedals should slide off of the shaft from the end that bolts to the bellhousing. The round collar on the shaft has a roll pin, but removal is not necessary.
Paul | | | | | Joined: Jun 2014 Posts: 20 New Guy | | New Guy Joined: Jun 2014 Posts: 20 | Hi Paul, Once I got the assembly off the truck and scraped 20 years of crude off it I found and removed a roll pin that allow me to drive the larger pin/rod out freeing the brake pedal. The clutch pedal did slide off the end off the free end. Replaced the bushings and all is well, except for now having to rebuild a master cylinder. Of course this is only the beginning of my journey. Where in WNC do you live? I am just north of Asheville. Troy
Tried to send you a PM and came up with an error message...shoot me a PM
Paul | | | | | Joined: Jun 2014 Posts: 20 New Guy | | New Guy Joined: Jun 2014 Posts: 20 | Paul, Tried to send pm but got message saying they are disabled. In my preferences and profile I don't see how to fix that. Any help....anyone?
New guy Troy | | | | | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | Until you've had 4 posts approved, you cannot use PM. This was your fourth approved post, so PM should work for you now. You can also now create a signature (My Stuff/Edit Profile) as well as use HTML and UBB for links and quoting, etc. | | |
