3 members (Bill Hanlon, FishinToms53, tesa), 110 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#1041565 07/11/2014 1:42 AM
Moderated
Moderated
I am new to this site and I would like to know where to find information for lowering the suspension on a 55 First Series.
Randy
Welcome to the site.
Info on modifications from stock is found in the HiPo forum. Your post has been moved there.
Are you staying with the stock suspension or updating everything?
Moderated
Moderated
Keeping all suspension stock. The truck is a daily driver however just would like it lower
What I did was have leaf springs rebuilt (you don't want to run a worn out main leaf) then removed a couple leaves, ended up with springs that were almost flat with full weight on front. You don't want springs going beyond flat. Then I went with a 2" dropped axle, don't know who can supply these today. Then the tie rod doesn't clear the leaf springs so needed to heat and bend steering arms down a bit to clear (btw have a pro do the heat/bending). Also went with modern tie rod & ends for more clearance at the wheels. Then BUMP STEER, so we bent the steering arm so that drag link is level with the ground.
That's about it, add some big and little tires and will look like an old timey rod. Best of luck
1946 1/2-Ton Chevy
contact sid at www.droppedaxle.com. He can help you with all of this, or just go look at his website. Great guy, I would go back to him in a heart beat!
