| | | Forums66 Topics128,052 Posts1,055,717 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | I own a 49 1/2 ton with a 54 engine, but still has the original rear end. does anyone have a suggestion as to what year new rear end to look for and where??? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | We need an idea of what your plans are for the truck before we can recommend a rear end or a tranny change. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | There is always the ring and pinion swap (3:55 to 1) using the original housing....
John | | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | Sorry.. It will be just a restored work truck, but needs to drive at highway speeds...65-70 mph | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You can buy a ring and pinion set for 3:55 ratio that you swap in your existing differential and torque tube in place of your 4:10 gears.
John | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | The only other way to get to 65 mph would be to swap in something like a modern 5 speed T-5 transmission and open type differential. John | | |
