| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I upgraded my driveline and ended up needing 5 bolt rims. Are there any stock 16" or 15"rims that I will be able to use the original hubcaps with? Carter has 5 bolt rims but you have to buy their hubcaps as well. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I did same thing on my '47 coupe 6 lug to 5 and bought a set of ralley wheels. Not happy with look of little 'police caps' so called WheelSmiths, they put together a factory looking 41-48 cap that fits perfectly on my ralley rims. With 5 lug rims I do not believe there is any other way to go. I'll attempt to send you a pic of my new rim/caps. http://www.thewheelsmith.net/http://www.petepaulsen.com/catalog/cataloghome.htmlBest of luck Jim
