3 members (asilverblazer, wvstovebolt, Bill Hanlon), 135 guests, and 3 robots.
Topics128,083
Posts1,055,967
Members48,430
#10408 01/23/2002 9:15 PM
Whats the differance in a GM 350 v8 fuel injected block and a later model carburated block? Can you use later model heads and intake on a newer fuel injected block and make it carburated? Thanks again! grin
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
#10409 01/23/2002 11:16 PM
Anonymous
Unregistered
Anonymous
Unregistered
Yep but most have no passage for the manual fuel pump.So.....you go to put one of them noisy electric pumps on.
#10410 01/23/2002 11:18 PM
Anonymous
Unregistered
Anonymous
Unregistered
opps plus the flywheel is diff if you have a wheel from a 2 peice rear main.The new blocks are 1 peice rear main with a diff flywheel.
#10411 01/23/2002 11:24 PM
Thanks Phat! Thought that was all there was but wasnt sure. Looking for a prospect for my power plant. Little hard to find a good older block that hasnt been bored a couple of times. Later! cool
