0 members (), 119 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
As the title says, I need to wire my build from scratch. It's a '50 3100. I have no wiring harness or really any good idea of where to begin but wanted to ask for some direction before I needed to know in the next couple of weeks.
The engine is a '60 235, 12v starter. I'd like it all to be 12v and I'm hoping to use an alternator if I can source a bracket for it.
voltage doesn't matter, a 6V harness has slightly heavier gauge wires, which adds a safety factor - the best thing to do is buy an inexpensive wiring harness for a 50, you can order it with the alternator option .... trying to wire it with off the shelf wire and terminals will not only be a lesson in wasting time, it would be more expensive than a repro harness, not as well done, and leave you with a bunch of left over wire - unless you plan on making all the wires the same color ... and good luck with that grin
I wired my 50 from scratch
Never wired anything before.
I started with the wiring diagram, then drew out each circuit on a piece of paper so I could understand.
This was suppose to be temporary while I saved for a road island wire harness.
Classic parts has a pretty good harness
If you're not worried about originality there are several generic harnesses you can use like Painless, American Autowire, etc.
My 46 GMC on Photobucket
I'm not, the only real concern is cost. smile
For good price and good quality, check out Classic Parts, as suggested by DAD50.
jr, with the price of copper nowadays you'll spend more doing it yourself than the repro harness would cost - believe me, I had to wire my bus from scratch and it is not cheap if you're going to do a good job of it
I used one from Hot Rod Wires on my '56. If you are planning to add air conditioning, radio, power ports, etc. that would be the way to go. You'll still be custom routing it but you'll have a harness to start with instead of having to buy all those wires.
If it's just a basic truck, I'd go with the Classic Parts one Tim mentioned. It looks like a stock harness.
Sir Searchalot
Sir Searchalot
There are two Companies: Mailing address says: Classic Parts of America (in MO.) and their Logo says "Classic Parts" and "Truck Parts" (was ChevyDuty.) Then there is American Classic Truck Parts in TX. I never know which one people mean when they say "Classic Parts". Don't know if they are literal or shortening the name. I'm slow at times. I like the one in MO.-Town and I believe that is the one they mean. Nevertheless, I recommend a kit with the more modern fuse panel included. American Autowire is the high end, but very nice and complete.
Classic parts . Com
http://www.classicparts.com/
Old chevy duty
I agree with that. It is well worth the price and easy to understand. Steve
The classic parts $150 harness.....
* would it work with a 12v generator system? And if so, what other gizmos might one have to add?
* my truck has a couple extra goodies. Spotlight and can market lights. Can this harness be added to or should I seek a different one?
1951 3100
I think the harness is offered in either generator or alternator.
For accessories, I'd add a 782-5316 fuse block.
Yes, alternator or generator - different part numbers.
The set used to come with enough lengths of wire to take care of turn signals (and a second rear lamp) - call them and check this out.
ojh Offline
As said, the least expensive is a generic harness. The difficult part using one of them is that they'll have turn signals integrated into the system. That will be no problem if you are using a newer steering colum, if you are using the original column with an 'add-on' turn signal switch then you'll have problems.
A shop is where you wash your hands before you pee.
Which generic harness is less expensive than $150?
The $150 Classic Parts plastic-coated harness is a year-specific harness. It uses the your original fuses/breakers. Jim Carter sells a similar harness.
generator harness and alternator harness
They used to provide enough additional different colored wiring for add-on signals. If you want signal-lamps, you might want to call to see if this is still the case.
If you want more circuits or want to use non-original circuit-breakers and/or fuses, a generic system/harness is what you might want to use (and, you will have to measure/cut/terminate wires).
