| | | Forums66 Topics128,179 Posts1,057,161 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I have looked thru my Factory Assembly manual and my Factory manual and I still have yet to find a part number for the front axle washer used on my 1948 CK4400 1.5ton. Does anybody have a part number for it? Thanks, Curt | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 801curt, where does this "washer" go and what does it do??? | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | 3B it sits behind the front axle nut, and provides tension on the outer race. Its a round washer with a small 'tooth' on the inside that fits into the channel on the spindle. In this picture it is sitting inbetween the axle nut and outter race . sorry its the only picture I had of it. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 801curt, the part number should be in group 6.321, in my Canadian parts book there are two different washers depending on serial number. | | |
