1 members (Stovebolt48),
71
Mod | | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10408 01/23/2002 9:15 PM | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Whats the differance in a GM 350 v8 fuel injected block and a later model carburated block? Can you use later model heads and intake on a newer fuel injected block and make it carburated? Thanks again!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
#10409 01/23/2002 11:16 PM | | Anonymous Unregistered | | Anonymous Unregistered | Yep but most have no passage for the manual fuel pump.So.....you go to put one of them noisy electric pumps on. | | |
#10410 01/23/2002 11:18 PM | | Anonymous Unregistered | | Anonymous Unregistered | opps plus the flywheel is diff if you have a wheel from a 2 peice rear main.The new blocks are 1 peice rear main with a diff flywheel. | | |
#10411 01/23/2002 11:24 PM | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Thanks Phat! Thought that was all there was but wasnt sure. Looking for a prospect for my power plant. Little hard to find a good older block that hasnt been bored a couple of times. Later!
