4 members (Guitplayer, Wally / Montana, 46 Texaco, 1 invisible), 59 guests, and 3 robots.
Topics128,264
Posts1,058,357
Members48,485
#1040703 07/07/2014 9:08 PM
I just encountered an area of old lead body work on my front fenders where I am going to need to do some welding, is there a way to clean the lead satisfactorally to weld it with a mig welder? Thanks, Scott
Ex Hall Monitor
Ex Hall Monitor
The best way is with a torch but be careful about putting too much heat into the panel. Melt a small spot and wipe it off. You can grind it but lead is soft enough to plug most abrasive wheels.
Melt and scrub with a hand-held wire brush, then use an angle grinder or DA sander to remove the residue. Back in the 1950's body men considered anyone who used more than 1/16" of lead to be amateurs- - - -not good enough to metal-finish a panel without using filler. Then Bondo came along, and good body work became a lost art.
Will the lead still be impregnated enough to cause any headaches when welding? I know paint rust and oil can cause some serious splatter, never dealt with lead. Scott
Lead "tins" to the surface of steel- - - -it doesn't penetrate very deeply. A good scuff job with 40 grit sandpaper will remove enough of the surface to prevent weld contamination.
