6 members (FishinToms53, Gdads51, Woodcmiami, TUTS 59, amtrakjoe, Otto Skorzeny), 140 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#1040650 07/07/2014 5:57 PM
1948 3100
I have all drum brakes. They have been changed to bendix. I have a 53 3100 torque tube and 53 3100 front end. I would like to put in a dual cell master cylinder without the power boost. I would also like to have the option of being able to convert to front discs in the future if I want to.
Question. Can I install the POL dual cell master cylinder set up for disc/drum with the proportioning valve? It is setup with 2 lb residual valve in front (disc) and 10 lb residual valve to back (drum). I would plan to change the front residual valve to 10 lb to compensate for the drums. And should I run all 1/4 inch lines?
Thank you,
Dennis
oldbluetruck #1040657 07/07/2014 6:18 PM
Second question. Are stock brakes sufficient if I put in the 3.55 gears?
Dennis
oldbluetruck #1040684 07/07/2014 7:47 PM
Stock brakes work fine for me in a 1954 Suburban (Bendix brakes) with 3.55 rear end. Your 1948 Huck brakes supposedly need more foot-pressure, so wait to hear from Huck users.
oldbluetruck #1041052 07/08/2014 10:16 PM
Thank you Tim. As always
Dennis
oldbluetruck #1041141 07/09/2014 6:49 AM
Blue,
I have never driven my truck or used the brakes (or lack of), but i bought disc brakes for the front along with a dual frame mount master cylinder. If you want the information on it, i can send it to you. I know plenty of other guys have already done this also.
Chris
oldbluetruck #1041319 07/10/2014 1:28 AM
It's been a while since I've driven a Huck brake vehicle (last one was in the mid '90s, '49 3800), I don't recall it really needing that much pedal pressure compared to my Bendix brake '55. Both are stock master cylinder non boosted systems.
Bill Burmeister
oldbluetruck #1041438 07/10/2014 1:50 PM
V
V Offline
I've got a 49 3100 and I went through and rebuilt the entire Huck brake system. Hard lines, soft lines, shoes, MS & WS's.
I've also got the 4.11 rear gears.
For normal brakeing the Hucks are more than adequate with my setup. They do fine in bumper to mumper but I try to avoid this type of cruising. They also do fine in normal type brakeing.
Where they need additional foot power is when stopping at speed. This is where the old term "standing on the brakes" no doubt originated from. When I say stopping at speed I mean like in a panic stop and/or stopping at the bottom of a steep grade at speed.
I have literally stood on the brake pedal in a panic stop. It stopped thank goodness grin
All the stopping power comes from you.....
It is definitely different than any vacuum assisted power brake setup we've all gotten used to, theres really no comparison.
Hucks don't self adjust so they need regular adjusting.
With 3.55 gears you'd probably want disc's in the front.
JMHO
Dave
oldbluetruck #1041476 07/10/2014 4:10 PM
I have bendix brakes
Dennis
oldbluetruck #1041667 07/11/2014 1:16 PM
V
V Offline
Sorry about that Dennis. I got lost somewhere in the thread and got off on Hucks, I see you said right off you had Bendix.....
Unfortunately I don't have a knowledgable answer to your question. I would guess that a proportioning valve wouldn't be necessary for Bendix drums on front & rear but thats just a swag on my part.
You could order a dual MS w/the proportionng valve and try it both ways, that is with the valve disonnected and then connected to see which way works best.
Good luck and sorry about the hijack.
Dave
oldbluetruck #1042632 07/15/2014 3:44 AM
No problem Dave. I enjoyed your comments. I'm not good when it comes to modifications to things and have decided to simply replace the original master cylinder with a dual cell one. Simple and should provide at least half brakes if anything goes terribly wrong. I just need to figure out how to check, fill and maintain the fluid levels when needed.
Thanks again
Dennis
oldbluetruck #1043400 07/18/2014 10:57 PM
Hi all, I have a 48 3100. With later drive line and brakes. I have drums all around, and a single red Master cylinder. I want to keep the drums all around and upgrade to a dual MC with power boost. I think my brakes are 53-55?
oldbluetruck #1043448 07/19/2014 3:20 AM
The dual cell master cylinder swap is fairly straight forward. You need a bracket and the proper m/c, and will have to run new lines. You can use your stock pedals and nobody will ever know the difference. The only major modification is the service location. You will have to cut a new access hole in the floor board. Installing the bracket and MC are pretty easy, my 13 year old installed mine. I bent and ran the lines and checked everything behind him. Truck stops on a silver dollar, now!
Mitch
oldbluetruck #1043452 07/19/2014 3:28 AM
I forgot to mention that my install was NOT power boosted. I've only ever put power brakes on my street rodded truck. I used one of the kits with the big ugly pedal. I'm not sure how to do the power booster on a stock drum system.
