| | | Forums66 Topics128,117 Posts1,056,298 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 37 New Guy | | New Guy Joined: Mar 2012 Posts: 37 | I know the frames are different on the farmtruck versus the half ton but are the cabs and front clips the same between the farm truck and the half ton | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any model could be a "farm truck", the 3100 is a 1/2T, the 3600 is a 3/4T .... the chassis difference is primarily in springs, wheels, and rear axle, not the "frame" itself, which are just different lengths .... all conventional cabs of a year are identical, and the front clips are the same 1/2T to 1T
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Frame is much different Bill. 9/64" vs. 3/16" thickness and taller by close to 1/8". Although the front looks the same, the 3600 frame is very narrow in the back compared to the 3100. http://chevy.oldcarmanualproject.com/chevyresto/5070.htm Also the cross members are quite a bit different with the 3600 using a center support bearing in it's drive shaft and no support at the rear of the transmission. DG
Denny G Sandwich, IL
