3 members (klhansen, Hotrod Lincoln, 1 invisible), 80 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#1040523 07/07/2014 4:21 AM
Ok I am kind of embarrassed about this, but have rebuilt the truck, and I change the oil religiously, but have not changed the filter in the oil bath. Going to order one any idea if it is a 5 inch or 6 inch usually found on a 48? They are cheap. How often do you change the filters?
Mike,
What year and style oil bath air cleaner?
Maintenance - 1948 Heavy Duty (Oil Bath) Air Cleaner
The filter element is not replaced in a 216/235/261 oil bath air cleaner. You clean the filter element in solvent/kerosene/diesel-fuel (the filter element is part of the top of the assembly), then empty the dirty oil from the base, and then add 50 wt engine oil to the base (up to the "oil" line in the base).
Thanks I need to do this soon! I am going to the wrong garages and they never mentioned it ever. So will get it taken care of!!!!Thank you!
Mike
The mesh in the oil bath filter is a flame arrestor also.
Thanks! Appreciate the help!
