| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 13 Member | | Member Joined: Jan 2003 Posts: 13 | my 51 3100 sat in a feild with about 400 lbs of chains and buckets of bolts on the passengers side floor for abouth 30 years the floor board was broke not rusted could the door post also be broken? if so can it be replaced? | | | | | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | WTD, It all depends on whom does the work, a pro can fix anything and,most of the parts are ready to order from vendors. If you want to do the work your self, depends on your skill level. You could really make a mess if you don't do it right. Classic truck Dec.2000 volume9 no. 12 onpage 58 has a good artical on floors and all the what to do's. They have a web sight at gr8ride.com Sure am glad your not WhatmayIdo, that would be WMD  | | | | | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | Well? Whats up did you get to the bottom of it? We are (all still here to help a fellow bolter out)give us an update to where you are. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | With all the chains and crap out of the cab do you see a "saging" in the floor? The door sill area at the edge of the floor to the outside should be perfectly flat from the front door post to the rear, is it?
Have you tried to loosen up the bolts on the door at the hinge on the top hinge and lifted the door?
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
