4 members (Uncles51, Chip O, Tronman, G508), 143 guests, and 3 robots.
Topics128,028
Posts1,055,413
Members48,422
#104018 11/02/2003 8:25 AM
my 51 3100 sat in a feild with about 400 lbs of chains and buckets of bolts on the passengers side floor for abouth 30 years the floor board was broke not rusted could the door post also be broken? if so can it be replaced?
#104019 11/04/2003 8:35 PM
WTD, It all depends on whom does the work, a pro can fix anything and,most of the parts are ready to order from vendors. If you want to do the work your self, depends on your skill level. You could really make a mess if you don't do it right. Classic truck Dec.2000 volume9 no. 12 onpage 58 has a good artical on floors and all the what to do's. They have a web sight at gr8ride.com Sure am glad your not WhatmayIdo, that would be WMD eek
#104020 11/13/2003 6:22 AM
Well? Whats up did you get to the bottom of it? We are (all still here to help a fellow bolter out)give us an update to where you are.
#104021 11/13/2003 7:30 AM
With all the chains and crap out of the cab do you see a "saging" in the floor? The door sill area at the edge of the floor to the outside should be perfectly flat from the front door post to the rear, is it?
Have you tried to loosen up the bolts on the door at the hinge on the top hinge and lifted the door?
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
