| | | Forums66 Topics128,062 Posts1,055,851 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | About 4 or so months back I scored a Unity OEM left hand spotlight for my GMC. All the brackets were included, which you need to mount and install the light correctly. HOWEVER, without the help of MARK BRAZELTON, who wrote up a very detailed procedure on the steps to take, I would still be scared to try and install the light. Well tonight after getting some help from Mark, I got the light installed perfect. Took about an hour, I read everything twice and did every step as a practice step first. One accessory down and about 15 to go http://community.webshots.com/album/577957428vTTyKeJake
| | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | that looks great! how hard are those to find? because I'd love to put some on my 62 GMC fire engine. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | You can get the lights from unity, but the correct brackets are a bear to find. The top of the bracket is curved to fit the lip of the area just so. I found this light on eBay WITH the brackets, that why I grabbed it for the $150.00. I still want to replace teh light switch but that's only 12.00, the wiring is a bit worn. http://unityusa.com/default.aspxBUT If you pick a spot or do a roof mount or other spot where the metal is flat, you will have no problem getting a light. I'm trying to do a 100% OEM period correct restration, so it was important to me (at least in my mind) to use the setup.
| | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Garandboy--you shouldn't have too much trouble finding spots for your fire engine--the fire trucks usually mounted them up high on the windshield pillar, near the roof, rather than at the cowl. Most firetrucks that I've seen had them there, though one did have them at the cowl.
I've been searching off-and-on for 4 years to get spot lights. I did some horse trading and got a factory driver's side spotlight with brackets for my '62 Suburban. Then the hunt was on for a passenger side. The driver's side is rare: the passenger side is extremely rare. I ended up finding a pair of NOS brackets for $160, and though that was stiff, I was happy to get them. Found a nice factory spotlight on Ebay last month, without brackets, for $72 shipped. I don't have the passenger side spot mounted yet, but I'm looking forward to getting it on the truck.
After wanting them for four years, I ended up with a matched set in under two months!
I found out that the OE brackets for the GM Accessory spots are part numbers 141RH/LH for the exterior (right hand or left hand), and 8205RH/LH for the interior. Unity also offered an aftermarket bracket that was sold by NAPA, Western Auto, etc.. Those brackets do not look the same at all--they're almost tear-drop shaped, and have a rather clumsy clamp for the light's shaft. I was also told they have a very slightly different mounting location from the factory spots. Those are Bracket Number 31RH/LH. I don't know what they did for the interior brackets, but have a note in to the guy I got mine from.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | For anyone interested, here is an email I just got from the guy who I bought my NOS bracket from. He's got the following in stock. He's heading out of town for a week, but he'll be happy to answer anyone's questions. "I've got a 47-55 first series spotlight, a 55-59, a 60-63, a 64-66 & a 67-72. I can supply any other those spotlights for the drivers side. This has been a busy month for me because of vacations and other business. I haven't been advertising at all. But I've got the lights." He can be reached at [email protected]. Like I said, I searched on and off for 4 years, so if I can save anyone else the search, I'm glad to help! -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | | | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | Can you send me -- or post --Mark Brazelton's detailed spotlight instructions? Thanks. I've got onlt one wire leading off from my 2 NOS GM left- and right-hand spotlights. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 54Carryall: are you asking how to wire? or more than that? Wiring is easy.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Nice! I had 2 cop lights on my 65 for about a year. Took em out and gave them to my buddy for his 38 dodge. It was fun messing with people with the lights.
| | | | | Joined: Feb 2010 Posts: 82 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Feb 2010 Posts: 82 | New brackets from Unity are still available, finding a dealer is tough. | | |
