| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello all, Working on my second 1.5 and I'm in need of rear park brake cables. I've checked all the usual sources with none new or used. Has anyone else ran into this problem and what was your solution?
Thanks | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Try Inlinetube.com They make parking brake cables. Kent | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I got new ones made for mine no problem and the price was ok. Only difference was, the originals are very strong and rigid, but the new ones used 6mm or 1/4 inch stainless cable. Nice but it's too stretchy and doesnt let the lever get a good pull on the brakes, so it lacks power. Something to check prior.
'47 Canadian RHD 1.5 ton truck
