| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 12 Member | | Member Joined: Oct 2003 Posts: 12 | I'm not sure if this is the right place to ask this, but here goes. I haul a lot of gravel and stuff in my '65 chev 3/4 ton. it will haul a 3000 pound load of gravel with little more than the rear tires looking slightly bulged. Anyway, I get irritated when gravel and stuff gets stuck down in the gap between the tailgate and the bed floor and causes the tailgate to get stuck. Is there any way to remedy this without it looking too tacky? I want it to look attractive. Also, on a completely different note, does anybody know where I can find information on the interior workings of car (latches and locks)? Specifically 91 oldsmobile cutlass ciera? The chilton and mitchel manuals show nothing of the sort. Thanks
The shortest distance between two points is probably under construction
| | | | | Joined: Oct 2003 Posts: 12 Member | | Member Joined: Oct 2003 Posts: 12 | error correction: interior workings of car DOORS...
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | A nice rubber flap should take care of you gravel. On the door handle controls, what exactly do you want to know? On what car?
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Oct 2003 Posts: 12 Member | | Member Joined: Oct 2003 Posts: 12 | a 91 oldsmobile cutlass ciera with manual locks and windows
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Did you try a library? In the bigger cities they usually have the factory service manuals.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2003 Posts: 12 Member | | Member Joined: Oct 2003 Posts: 12 | I've checked every mitchell and chilton manual in my library and none of them show anything about doors or their internal workings...
