6 members (Samantha, tclederman, TUTS 59, Otto Skorzeny, Mike Roache, Steelonsteel), 48 guests, and 4 robots.
Topics128,036
Posts1,055,458
Members48,422
#103996 10/15/2003 5:41 AM
I'm not sure if this is the right place to ask this, but here goes. I haul a lot of gravel and stuff in my '65 chev 3/4 ton. it will haul a 3000 pound load of gravel with little more than the rear tires looking slightly bulged. Anyway, I get irritated when gravel and stuff gets stuck down in the gap between the tailgate and the bed floor and causes the tailgate to get stuck. Is there any way to remedy this without it looking too tacky? I want it to look attractive. Also, on a completely different note, does anybody know where I can find information on the interior workings of car (latches and locks)? Specifically 91 oldsmobile cutlass ciera? The chilton and mitchel manuals show nothing of the sort. Thanks
The shortest distance between two points is probably under construction
#103997 10/15/2003 5:44 AM
error correction: interior workings of car DOORS...
#103998 10/15/2003 6:54 AM
A nice rubber flap should take care of you gravel.
On the door handle controls, what exactly do you want to know? On what car?
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#103999 10/17/2003 6:21 AM
a 91 oldsmobile cutlass ciera with manual locks and windows
#104000 10/17/2003 3:39 PM
Did you try a library? In the bigger cities they usually have the factory service manuals.
Fred
52 3600
69 C-10
#104001 10/18/2003 4:20 AM
I've checked every mitchell and chilton manual in my library and none of them show anything about doors or their internal workings...
