| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Hello. I just pulled the oil pan on my 216. A lot of sludge and grime. Any recommendations on how/what to use to clean? What the process is? The manual says to check alignment of oil nozzles, so I just don't want to do something stupid that is going to set me back more. Thank you, Judson | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Any sort of degreaser should work. Try and scrape out the worst of it, then wash it up with a degreaser and a parts washing brush. They make a lot of these water based cleaners anymore, never used them myself.
John | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | A pressure washer is a good idea if you've got a place to drain the crud without getting the enviro-nazis on your case. I've been known to sneak into the friendly local coin car wash late at night for such projects and use their engine degreaser option for that kind of stuff. Since you're in Commiefornia, that might be a problem. Once the pan is clean, aiming the spray tubes is simple- - - -scribe an "X" on the side of the oil pan directly across from each nozzle, attach a water hose to the supply tube, and bend the nozzle up, down, or sideways until the stream of water hits the middle of the X. Rinse and repeat for all six nozzles! Jerry
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | A pressure washer is a good idea if you've got a place to drain the crud without getting the enviro-nazis on your case. I've been known to sneak into the friendly local coin car wash late at night for such projects and use their engine degreaser option for that kind of stuff. Since you're in Commiefornia, that might be a problem. Once the pan is clean, aiming the spray tubes is simple- - - -scribe an "X" on the side of the oil pan directly across from each nozzle, attach a water hose to the supply tube, and bend the nozzle up, down, or sideways until the stream of water hits the middle of the X. Rinse and repeat for all six nozzles! Jerry And here I thought you had to have a special tool for that..... Good tip Hotrod Lincoln. John | | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | | | |
