| | | Forums66 Topics128,093 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10393 05/22/2002 12:32 AM | Joined: Sep 2001 Posts: 13 Member | | Member Joined: Sep 2001 Posts: 13 | hello there. I have made up my mind. I am going with a 250 truck eng with offy 3x1 setup. this is going in a 50 fleetline. There is nothing wrong woth the orginal motor. I just get scared sometimes. 52 years. no maintenance. wow. But now I have this 250. complete job. actually I built a 350 for it but it just did'nt feel right. I really like the inline engine and I know it is capable of some power. tell me what I need to do. Will the tranny bolt up. It looks like the same bellhousing. has anyone done this swap before out there. if so tell me what went wrong. I know I will have to use different motor mount. It just feels better than a 350. everyone has one of those. its a 250 out of a 70 nova. help anyone???? justin
justin kohut 1950 fleetline/kustom 1950 Buick super (straight eight)
#10394 05/22/2002 11:22 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | "There is nothing wrong with the original motor." I'd think long and hard about that before going through with the swap. Are you ready for everything going wrong? In any case, my build sounds similar: http://www.homestead.com/chuckthetruck/page1.html | | |
#10395 05/23/2002 6:07 AM | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | I have a 1968 250 in my '37. I had to make different mounts. Does your transmission mount like a normal new car with one rubber tail shaft mount? If not, you may have trouble mating the engine to it. I used a late model automatic so it was pretty easy to change over. Also, the 250 is a longer engine and I had to set the firewall back a few inches for everything to clear and have some air space around it. The fan on the 250 will set lower, I had to lower the radiator to get full air flow from the fan. The radiator must be in good condition or you may have heat problems. I took the top tank off my and really cleaned it out, Still ended up with a new core. I think the 250 runs a little hot and doesn't hold much water in it. It takes a good radiator to control it. Is your temp gauge a manual type, with the copper tube and bulb on the end. The sending unit mount on the 250 is clear at the front of the head, will your tube reach it? My didn't, $75 later I now have a new gauge that works. How is your exhaust, it will take larger pipe if you want it to run good. Have I scared you yet? Joe | | |
#10396 05/23/2002 6:47 AM | | Anonymous Unregistered | | Anonymous Unregistered | I agree, nothing wrong with that 216. You will have to do alot more modifications to get that 250 to fit as compared to a later 235. 216 to 235 is a natural conversion 216 to 250 is not. | | |
#10397 05/23/2002 12:58 PM | Joined: Nov 2001 Posts: 9 Member | | Member Joined: Nov 2001 Posts: 9 | But will an automatic of recent vintage fit up to a 235? Or will you have to use an older automatic? I understand that the older ones are expensive to rebuild and unreliable?... Are adapters available that work? | | |
#10398 05/23/2002 3:04 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hi 52,
I'm afraid its a "no". The 216/235/261 bellhousing is different from the later 250 bellhousing. No modern standard or auto tranny will fit a 216/235/261. There are adapter plates available, but I've heard of several of them cracking. Does your truck have a torque tube? If so, you'd have to swap the rear axle to use a later tranny, and have a custom driveshaft made. You'd also have to buy/build a custom tranny mount.
Swap in a 235 with an old Hydramatic or a 3 or 4 speed (235 era) standard tranny. Otherwise, go ahead with the V8, cuz the work to put a V8 or any later I-6 would be about the same.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
