4 members (Hotrod Lincoln, Otto Skorzeny, Bill Hanlon, 1 invisible), 70 guests, and 1 robot.
Topics128,090
Posts1,056,026
Members48,432
Can anyone tell me if this is a 1 bbl Rochester? I assume it is but have never seen one.
Carb
I hear these are kind of dogs. I don't want to go crazy with headers and dual exhaust and double carbs, but can anyone tell me what a step up in carbs would be for good efficiency on a daily driver?
It is a Rochester B
You could start looking for a carter 2100S or just rebuild what you have that Rochester is not a bad carb it's a very simple carb and easy to rebuild and adjust.
Is that a 235?If it is than the carter 2100S would be the replacement carb for it.
Pete
I've run a holley/weber from langdons stovebolt on my .060 261 with no problems for 5 years,got good mileage on the highway with it. Just recently changed to a later model rochester monojet and the improvement in response is nice and smooth, the engine runs great at low, med., and high speeds. However the milage has fallen off a little, but that may be because my foot is into the gas pedal a little more.
Tommy
59 apache 1/2t
261 short stepside
Pete
I didn't know they were decent. It may also not need rebuilding - I bought the engine in running and recently rebuilt condition.
What is the difference between a carter w1 and a carter yf? Is there another suitable replacement for the w1? '42 p/u 216.
Ridge dweller
