1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Can anyone tell me if this is a 1 bbl Rochester? I assume it is but have never seen one. Carb I hear these are kind of dogs. I don't want to go crazy with headers and dual exhaust and double carbs, but can anyone tell me what a step up in carbs would be for good efficiency on a daily driver? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | You could start looking for a carter 2100S or just rebuild what you have that Rochester is not a bad carb it's a very simple carb and easy to rebuild and adjust.
Is that a 235?If it is than the carter 2100S would be the replacement carb for it.
Pete | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I've run a holley/weber from langdons stovebolt on my .060 261 with no problems for 5 years,got good mileage on the highway with it. Just recently changed to a later model rochester monojet and the improvement in response is nice and smooth, the engine runs great at low, med., and high speeds. However the milage has fallen off a little, but that may be because my foot is into the gas pedal a little more.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | You could start looking for a carter 2100S or just rebuild what you have that Rochester is not a bad carb it's a very simple carb and easy to rebuild and adjust.
Pete I didn't know they were decent. It may also not need rebuilding - I bought the engine in running and recently rebuilt condition. | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | What is the difference between a carter w1 and a carter yf? Is there another suitable replacement for the w1? '42 p/u 216.
Ridge dweller
