1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#103923 09/20/2004 4:37 AM
Junior Member
Junior Member
' Offline
"Lazarus" has a pretty good body with little rust. The only problem is with the front right fender. The back bottom of the fender is folded in pretty far and has a fold "crease" in it.
I have tried almost everything I know to pull it back out, even tried using a "BIGGER HAMMER" with no luck. Is it necessary to heat up the metal to straighten this out? I am by no means a body man and if I can help it, don't want to take the fender off to work on it. Any suggestions?
Thanks :rolleyes:
#103924 09/22/2004 1:37 PM
This is a comment from someone who is "learning on the job". I straightened out my old front fenders to see how close to proper form I could get them. They were pretty trashed and bent up but I managed to get them back very close to the proper shape. I ultimately bought some used replacements because the old ones were too far gone, rust wise.
When a fender buckles perpendicular to the impact force, which is very common, the metal cannot be straightened by simply hammering at the crumpled area. This causes further damage and distorts the metal in a different way. The fender has to be pulled out the exact opposite to the way the force was applied. At the same time, the crease can be worked on to allow it to move.
I found that the metal seemed to have a "memory affect" and the closer it got to the proper shape, the more stable it was.
1951 1 Ton Completed
