8 members (RAC1812, cmayna, WICruiser, GRNHydra, Otto Skorzeny, HandyAndy, Peggy M, 1955 1 Series),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | I thought all flat six`s had the dual inspection covers over the pushrods? Mine has one long rectangular piece almost as long as the block. Same as the valve cover, it has just the two bolts on top. Someone want to school a newbie on these engines? I want to buy a gasket set, just want to confirm what year and size I have. Where to look for numbers on the block would be helpful. Thanks,Darcy | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 |
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Darcy,
Post the engine serial number that is pressed into the block, just to the rear of where the distributor goes into the block. That should tell us the year and size of engine.
Some Canadian engine side covers were a little different from USA engines, depending on the year/engine.
The single long side cover was used on 216s and some 235s in USA. The two-bolt valve cover was used through 1953.
| | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Thanks. I`ll get the numbers in the morning. This motor seemed partially stuck. Pulled the valve cover and had a stuck valve. Pulled the head and the rear piston is wonky. I can move the engine back and forth abit and it only moves slightly. If I push on the top the rear piston, it goes down to a stopping point while the other pistons don`t move. Almost like a broken rod. HMMMM, time to swap to plan B and put this truck on a s-10 frame and power plant.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | It is kind of odd how they mix engines around anymore in terms. I had always knew an overhead valve 6 as an I-6 (216, 235, 261 ect....) An L-6 was a flat head engine or one having the valves in the block (Ford 226, Nash 172, Chrysler engines 207, 217, 230, 236, 250, 256 and 264 6 cylinders and others such as Hudson, Studebaker ect....) Then of course you had the F head engines such as Willys' F-134, F-148, F-161 which had the exhaust valve in the block and the intake in the head. Anymore an L-6 seems to be any inline 6 cylinder engine and an F6 is a flathead.... Times change I guess....:-)
John | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | John, you are correct in the use of the terms. Let's keep it that way. I heads are either conventional or overhead cam. The F head was a cross between the I and L, and last used in the 1971 Jeep. The L head has the valves in the block, hence the "flathead" which only had the combustion chambers. It dropped out of production here in the '60s. There obviously cannot be an F6 flathead! | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Hi Darcy. The 216 that came with my '52 GMC truck had a short side cover, and I swapped to a 216 from a Chevy '51 car that has a tall side side cover. Both engines have 2 valve cover bolts. | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Thanks. I was so used to my 50 dodge that had the different six in it. Anyhow, this one needs coin which I will put into going to plan B....frame swap. | | |
