0 members (),
82
Mod | | | Forums66 Topics128,090 Posts1,056,378 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | 55 Series 2, auto transmission, small hump.
Finally ordered the carpet and heat shield (2 pieces) and they will be here today. Any advice on the install? I'm going to clean the area very well, then spray 3m Super 77 on the heat shield then place it on the floorboard. Was also going to use the Super 77 to attach the carpet to the heat shield.
Looking for any advice/guidance from those who have done it before.
Thanks in advance.
1955 GMC 100 Series 2
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might be a better idea to glue the carpet to the heat shield and use the factory pegs to hold the combo down, most repro carpets have the holes for that .... glue everything to the floor and how do you know what's happening under there? also need to consider what you'll do when someone needs to open up that trans floor cover, or how you get carpet out if that becomes necessary some day
Bill | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Thanks Bill. Can you help point me in the direction of the floor pegs. I can't find anything on classic industries or lmc.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you won't find replacements they are part of the floor, they're welded on, if yours are gone you'd have to make your own, which could be screwed in - look around the top outside corners and near the outside corners of the seat - looked at my 58, also look each side of the firewall 'hump' on the level the top of the carpet would be
