5 members (Jon G, Hotrod Lincoln, 3800GUY, Wally / Montana, 1 invisible), 74 guests, and 2 robots.
Topics128,109
Posts1,056,569
Members48,448
U
U Offline
I bead blasted my bellhousing to bare metal, aired it off, wiped it down, dried it again, and then primed it with Rust-Ol self-etching spray primer just to prevent rusting...Now I'm concerned I should have used a high-temp primer on the bellhousing due to its engine proximity/contact.
Should it be ok with the Rust-Ol self-etch primer there? Anyone have experience with this particular self-etching primer? I'll eventually be painting the bellhousing & engine the same Chevy blue once I can get the engine repaired.
Brad
Wrench Fetcher, PhD
"high temp" usually is hundreds of degrees, if your bellhousing gets that hot you better not be in the truck, it's burning grin
U
U Offline
LOL, Bill - Understood... I was more wondering if what I put on it was permeable or porous? Or not the right stuff.
The bellhousing as it sits is better off than it's been in many years, I just don't want to paint it & have it come right off because I used an improper primer.
Brad
Wrench Fetcher, PhD
